Kyocera TA420i sporadic black pages
  • copiertec
    • Jan 2016
    • 2206
    scan.pdf I was called out for sporadic black images ( I have attached a photo), the customer stated it is sporadic. Upon arrival I printed out a maintenance report and the first two pages came out like the above attached image and the rest of the report came out good. I made a test copy from the glass and the fist 2 copies came out black and the rest were fine. The count on the maintenance kit is roughly 185k, the customer only uses OEM toner 1) I checked wall voltage and ground- good 2) I removed and cleaned charge corona unit and all contacts, 3) I cleaned the edge of the drum unit where it seems toner was building up 4) I cleaned transfer roller assembly and tested. It seems the copier is working at this time since I cleaned everything at this point. My question- I was wondering if Kyocera put a bulletin out for an updated corona unit for this series? I remember a tech bulletin a being posted about an updated corona unit but I can't seem to locate it. Thank you in advance. The paper is set up to run 8x11 though the MFP.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    Re: Kyocera TA420i sporadic black pages
    You are correct.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • LNorris
      • Sep 2008
      • 645
      CS420i-520iENTB3.pdf
      • copiertec
        • Jan 2016
        • 2206
        Thank you, I'm sure installing the updated one will resolve the issue.
          • 23008
          Me too. Those are typical charge loss symptoms. Keep an eye out for pinholes in the drum surface. The drum may also be damaged by the arcing. =^..^=
          • copiertec
            • Jan 2016
            • 2206
            Thank you, Blackcat, I will look for pin holes on the drum surface.... I hope I don't find any. If there are, do you think they will cause issues as far as copy quality or possibly more arcing after I replace the charge corona unit?
              • 23008
              If there are pinholes, you'll see them as white specks on black background or black specks on white background. You will not be able to see anything on the drum surface. It's strictly an electrical phenomenon, nothing visible on the surface. If you can live with the specks, they will not cause an arcing problem by themselves, as long as the charge unit is new. Did I explain that clearly? =^..^=
