job log removal from fs-1135
  • subaro
    • Oct 2010
    • 1274
    Anyone know how to remove the job log from the command center under the JOB menu. The history is there that i want to remove. there is no check box as in the address book to delete.
    • 22999
    Re: job log removal from fs-1135
    Have you tried an engine board reset? EGRE? =^..^=
    • subaro
      • Oct 2010
      • 1274
      In the past i have tried that command and it does not work with this model. I'll give it a go once more after udating firmware ect.
      • JR2ALTA
        • Feb 2010
        • 2031
        i suppose you could back up data and then run a sim21
        • subaro
          • Oct 2010
          • 1274
          This machine does not have service mode u21. Some other models did not have them initially, [fs-3640 -- fs2626 ] . Later firmware update added u21 and some other adjustment modes. The job logs contain previous custome email address which should be wiped when re-deploying the machine. dealer support is my last resort, so may have to shoot them the question.
