Maintenace code ??
  • copiman
    • Sep 2011
    • 861
    Maintenace code ??
    I have a Kyocera 6550ci that is indicating " Time for Maintenance C and D".
    I know what "C" is but I do not know what "D" is. Anyone know? I have searched the SM and other and cannot find it.
    I also have an 8000i that has "Time for maintenance "T". I saw a post that said just reset it U906. And something to do with setting install date and/or the time? Could someone elaborate on this as well?
  • ntbann
    • Jan 2012
    • 628
    Re: Maintenace code ??
    Maint. D is a black PM. All maintenance letters are on tech bulletin #1. 906 for maint. T reset and make sure time and date are correct on the machine.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      ntbann is correct. D & E were added after the machines were out. It's updated in bulletin #1.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • subaro
        • Oct 2010
        • 1274
        Actually D AND E is not in bulletin 1 , but on updated bulletin number 12 ....... ADDITION OF TWO 300K MAINTENANCE KITS TA 6550ci/7550ci-12
        Looked at bulletin 1 and did not see it there, but saw it on bulletin 12 on the bulletin section for this machine.
        • copiman
          • Sep 2011
          • 861
          Thanks everyone. Once again you have been very helpful. I did not see it at first in the bulletins. I just used TB1. Thought they would have updated it but apparently not. Learn something new everyday. Thanks again for your help.
          • subaro
            • Oct 2010
            • 1274
            Just a note here about kyocera bulletin1. Bulletin1 is never modified from its original issue. Any changes is made in subsequent bulletins as in this case Bulletin 12. Every model has a bulletin section [ kyocera kdaconnect dealer login website ]and all update are listed there.
            Note also. Some of the technical bulletins and machine modifications are only found on their ASTEA website and not on kdaconnect.
            • copiman
              • Sep 2011
              • 861
              Thanks again for your response. Very helpful. Where is the ASTEA website? First I heard of this .
              • subaro
                • Oct 2010
                • 1274
                If you are a dealer then contact your kyocera service rep for all the details.
                • copiman
                  • Sep 2011
                  • 861
                  I contacted my rep and I now can see what you were talking about. Will need to play around with it in order to get familiar with it because it seems very broad when searching for info. Thanks again for introducing me to ASTEA.
                  • subaro
                    • Oct 2010
                    • 1274
                    Very broad is putting it kindly. It is as backward as can be. The search engine makes you work hard to get some measure of results. But mind you, this is not kyocera website, but a portal that they use. It is better than nothing and you can place call for technical help there, look at past Q&A and bulletins. That search engine is not for this modern era, totally backward.
                    • wragsdale
                      • Jul 2014
                      • 188
                      I wish they would address how unintuitive the portal is, especially the search engine. You can't search for a number because if your search criteria shows up within another number or serial, it returns as a result. Not only that, but I can only use certain workstations/browsers to pull up resolved calls. It is almost a non-functional site for me.
