TaskAlfa 1801 warming up in energy saver mode
  • White_Toner
    • Aug 2009
    • 71
    Hi to all!
    This machine goes to energy saver mode after copying
    or USB printing. No problem. Temperature of heat roller about 60C
    If customer print through network controller, machine prints staying
    in energy saver mode, but temperature of heat roller about 170C,
    Lamp flashing like machine is printing/ So, strong smell of plastic in office.
    All resets were made, timings e.t.c. I couldn't understand is it software
    problem (last version is on machine) or no.
    Situation is the same in different nets (3 of them)- machine is the same :-)
    reports are here http://www.mediafire.com/download/vl...801_report.pdf
    • 23010
    Re: TaskAlfa 1801 warming up in energy saver mode
    Are you using the KX driver? It sounds to me like the print driver is continuing to send data, long after the print job is complete.
    I think I would use Deleter to remove all traces of the current driver, then re-load the KX driver. There may be other drivers sending to this IP address, so it may be beneficial to change IP addresses. =^..^=
    • White_Toner
      • Aug 2009
      • 71
      to BlackCat
      Different drivers and different nets - the same machine.
      New network card installed- no result/ Fuser warming up.
      If UI is active and you print using network, machine goes
      to energy saving mode correctly/
