TASKalfa 3050ci with C-2103 Error
  • EDSNOW
    • 180
    [Error Code] TASKalfa 3050ci with C-2103 Error
    Good Day
    The error code first showed up a few weeks ago.
    At that time the firmware was updated and the developer units inspected.
    I did note that there was a build up of toner in the developers. Did some cleaning.
    I also looked over the KDAConnect trouble guide for this code and see that CYM developers might require replacing.
    Machine is just over 3 years old and not a lot of volume. (300K total)
    I am prepared to change out the developers but I wanted to reach out and see if anyone else might have had a similar issue.
    As I had a callback Friday and see the code had come back I will change units this week.
    Thanks in advance for any replies.
    Edsnow@yos-wbm.com.
    • 23002
    Re: TASKalfa 3050ci with C-2103 Error
    As far as I can tell, there is no C-2103 code.
    Maybe C-2102 or C-2203? =^..^=
    • EDSNOW
      • 180
      Thanks for the reply Blackcat but there is a C2103 code for this product. It does have a trouble flowchart with the title developer motor
      but as one of the suggested solutions changing the developer(s) is listed.
      Sorry for any confusion.
      KDACONNECT
      TECHNICAL SERVICE NAVIGATION SYSTEM
      I do appreciate the response.
      Kind Regards
      • Santander
        • May 2009
        • 768
        Unless you can detect one of the DV's being obviously bound up rotating the gear manually, I would go for the motor first and not the DV's. We have had a couple of these and they turned out to be the motor.
        • EDSNOW
          • 180
          Many thanks
          I will check the motor drive first and go from there.
          I will advise the outcome of which component gets replaced.
          Regards
          Ed
            • 23002
            A simple test would be to unmount the developing motor with the plug connected, then watch to see if it runs in U030. It will detect a drive error eventually, but you should get 4 or 5 seconds of rotation before it detects the error. You might need an extra set of hands to start the sim. It's kinda hard to stand on both sides of the machine at the same time, simultaneously. =^..^=
            • EDSNOW
              • 180
              Many thanks again Blackcat.
              I will have the other tech come by Tuesday and try your suggestion.
              Regards
              Ed
              • EDSNOW
                • 180
                FYI
                I had a chance to go back to the machine today and it looks like the developer drive motor(s) are causing the code.
                I did try new developers/drum units to test. I also used M-mode 30 for the motor drives and the motor(s) were turning.
                Back to the drawing board.
                Regards
                Ed
                • simonsays
                  • Aug 2013
                  • 95
                  KDACONNECT
                  Kind Regards
                  you should have done a 089 first thing and see what each developer looks like. this would have been the first thing to do in the troubleshooting process this is a very common problem on these machines
                  • EDSNOW
                    • 180
                    Thanks for the reply.
                    I will advise the final outcome.
                    • Rpizzle
                      • Mar 2014
                      • 47
                      i would check too make sure none of the developers are backed up first.
                      • EDSNOW
                        • 180
                        I am changing out the DR-8505 unit when it arrives and will advise if this resolves the issue. (This Thursday)
                        Ed
                        • EDSNOW
                          • 180
                          Installed the new DR8505 unit and problem appears to be resolved. I must say the installation was quite straight forward.
                          Thanks for all of the replies.
                          Ed
