New boxes
  • Robob
    • Dec 2011
    • 21
    #16
    Re: New boxes
    Yep! My first service call on a TaskAlfa 6052ci today was for a mystery squeak. Customer said it is loudest in the morning when it's cold, but I never heard it. Did get some pretty good entertainment out of them trying to imitate the sound, though!
    I'll check the exit rollers if it comes back and keep an eye on this thread.
    Thanks guys!
    • qbert69
      • Mar 2013
      • 1152
      #17
      Re: New boxes
      Problem in the way that if the customer EXCEEDS the 30% Color and 70% B&W, which I think is the correct ratio, and they print MORE color, you're either gonna be emptying the Black waste toner bottle for re-use (don't loose the gear!) if you don't have a spare waste toner! Not sure if there is a part number out there just for specifically the waste since it usually uses the black bottle to be swapped down and re-used!
      DOH!
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • JVergin
        Service Tech / IT Rep
        • 216
        #18
        Re: New boxes
        DOH!
        Part#1902ND0UN0
        WT-8500
        According to Bulletin #1 of the new models, all of these have the same waste toner container WT-8500:
        2552ci, 3252ci
        3552ci, 4052ci, 5052ci, 6052ci
        4002i, 5002i, 6002i
        We've got a few sitting on the shelf just in case
        • Lunatech
          • Oct 2012
          • 208
          #19
          Re: New boxes
          So each can use their own black toner bottle as a waste and their is one waste toner container that will fit all. Makes one wonder how different all those different toners are.
