taskalfa 6550ci
  • TECHKYO
    • Aug 2016
    • 15
    taskalfa 6550ci
    I am having problem with taskalfa 6550 ci yellow color not printing?
    what I have done :
    1- Replaced dev. unit for yellow
    2- Replaced drum for yellow
    3- Replaced H.V PCB
    4- Replaced Transfer H.V
    5- firmware updated to the latest
    6- Replaced Engine PCB
    any suggestion please ...
    thanks
  • subaro
    • Oct 2010
    • 1274
    Re: taskalfa 6550ci
    In service mode run u089 and print out colour belt
    If the laser is defective, you would get blank print and copies. Not sure if the laser can be swapped with cyan, but that is the step i would take to troubleshoot the problem or just replace the laser with a new one. check if the machine is under warranty and order the part as such.
    • CWP
      • Jun 2013
      • 168
      Re: taskalfa 6550ci
      Best way I have found to troubleshoot laser is to cover a portion of the charge roller with a piece of tape and run a print. In this case, put a 1/4 to 1/2 inch wide strip of tape around the yellow charge roller (make sure it won't come off), and if the laser has failed, you will get a void of yellow except where the tape is. If there is no yellow at all, then you should look elsewhere.
      The best tape I have found for this is that stuff the painters use for trim (probably no prof. painters, but amateur painters like me).
      • TECHKYO
        • Aug 2016
        • 15
        Re: taskalfa 6550ci
        laser can be swap to cyan or magenta or black I did that but still machine no yellow print, I am going to re-check the machine by tomorrow then I will update you guys.
        thanks all for your commitment
        • habik
          • 2013
          Re: taskalfa 6550ci
          Any sign of HV 1st transfer connection failure for transfer belt?
          Have you tried halftone print and pulled the transfer belt and drum out?
          Bad
          Cover half of yellow laser window with tape. Print some yellow halftone page A3 size. Check for any hints of yellow.
          Is developer toned with yellow toner?
          What about settings?, anything out of wack?!
          Byting on bits.
          Firmwares HERE
          • copier_doctor
            • Dec 2014
            • 5
            Re: taskalfa 6550ci
            Have you confirmed you are getting developer drive? I have seen the DV drive unit cause this issue..
              • 22999
              Re: taskalfa 6550ci
              If the developer drive was lost, you'd have "Toner Add" messages, and low toner density codes. I think he would have noticed those. =^..^=
              • TECHKYO
                • Aug 2016
                • 15
                Re: taskalfa 6550ci
                hello guys
                here the update
                replacing Laser FFC wire and machine working smoothly part # 2K946B20
                even the old one look good
                thanks all for help
