3051 Ci poor CQ , light output
  • Geo
    • 662
    [CQ] 3051 Ci poor CQ , light output
    Hi All
    Have a 3051Ci with 137 K on color and 240 K on B.W.
    All colors except M are fading in the rear in varying degrees. Half tones look good ,but the solids fade toward the rear. The black color belt sample was done with the charger removed from the black drum unit. The faded pattern is what I am getting on the solids but not to that extent.
    I tried the following without any improvement..
    Ran the standard M.M. and DV refresh without any improvement M.M. 410 and 412 error out
    Transfer belt
    Charger Rollers
    Drum assy.
    Reseated H.V PCB
    Cleaned and checked all the grounds.
    Cleaned laser assy.
    What's bugging me is that chargers on K,C and yellow develop a whitish coating with in 400 copies, bet the M stays clean. AND swapping the K drum with M does not change the image ( M still is good and K still is bad.)
    Any thoughts
  • wragsdale
    • Jul 2014
    • 188
    Re: 3051 Ci poor CQ , light output
    Looks like developer bias. I would suggest replacing the affected developer units.
      • 23009
      Yup. Black developing unit will resolve this. I've seen it before. =^..^=
      • Geo
        • 662
        Hi All
        I thought about the DV units...but three failing at the same time with the exact same symptoms ? This just seems unlikely , unless something else is happening. Blackcat ..are you saying that a bad K Dv unit will affect yellow and cyan?
        Geo
        • darry1322
          • Oct 2010
          • 817
          I had this same symptom on a 3051Ci. Cyan was the worst. After changing the cyan unit all others cleared as well.
            • 23009
            Originally posted by Geo
            Hi All
            Geo
            The U089 Sample set can remain entirely unaffected by this problem. It goes entirely unnoticed in fill rates below, say 65%. In fill rates above 65% it gets very noticeable. Your internal test pattern is mostly 20% fill of each color and a very narrow band of 80% fill between.
            Depending on the colors present in your test pattern (especially the second page of your sample), you can see that CMY are entirely present, and only the black component is missing from those 80% fill areas.
            AlphardII black developing1.JPGAlphardII black developing2.jpgAlphardII black developing3.JPG
            In situations like this, this test pattern is very helpful:
            Yes it's just the black. And I'm glad that you're looking and thinking. When you print off the attached test pattern it will only affect blocks above 65% fill and at the interval. =^..^=
            • copier parts n.ireland
              • Nov 2016
              • 41
              ive replaced on average 2 develeper units per copier thankfully covered under warranty on about a dozen utax 3005ci/3050ci copiers now,always seems to be magenta and cyan units,our service department is still looking into problem and have been told to start installing cassette heater elements.
