M6526 CDN Weird issue
  • Dickie
    • Nov 2011
    • 190
    Engine prints are fine
    Scans are fine
    Black and white copies are fine
    Colour copies appear slightly blurred as if the colour registration is slightly out and appears to get marginally worse from left to right
    Logic says its not scanner as black copies are o.k and colour scans are o.k
    Logic also says its not engine as all engine prints and computer generated prints are o.k
    Sorry unable to post any images but do not think it would show up on a thumbnail anyway, as the effect is slight but is noticeable.
    Any ideas greatfully accepted
    • 23009
    Re: M6526 CDN Weird issue
    Have you done the color calibration? =^..^=
    • Santander
      • May 2009
      • 768
      Have you done a detailed color registration chart and done the adjustment? Also have you done a gray scale scanner adjustment to to match the scanner to the print engine? Since you say print engine prints are fine and printed pages are OK, this would only leave the scanner adjustment to match the scanner and print engine.
      • Dickie
        • Nov 2011
        • 190
        Have done colour calibration Blackcat.
        Santander, have not done either of these adjustments as I do not know where they are.
        Are they in service mode ? if so can you point me in the right direction as I did not see them in the service adjustments available from the control panel.
        Also if so, how do you access service mode on Kyocera colour machines ?
        I am trained on Kyo B & W machines badged Olivetti and have worked on a few of these small colour printers and MFC's mainly replacing consumables and dev stations after customers have used compatible toner
        Thanking you in anticipation
        • Dickie
          • Nov 2011
          • 190
          Thanks for first set of replies, but am still awaiting reply as to where the suggested adjustments can be found
            • 23009
            I hear the service manual has a whole chapter on this topic. =^..^=
