TA4501i C0800 and Jam 0100
  • habik
    • 2013
    Just FYI.
    Found something interesting when using ADF and or your machine starts to freeze or you can't cancel a job unless you do U906 or reboot.
    Look for trapped ADF wire harness or broken cable or something of that nature. Mine got pinched so it was easier to spot. If it would brake without being seen the point of breakage it would take me a lot longer.
    Those codes correspond to MFP board so signalling corrupt.
    Hope this helps scratching heads..
    Firmwares HERE
    • 23008
    Re: TA4501i C0800 and Jam 0100
    Congratulations on a great find! Harness problems can be very difficult to track down without completely pinning it out. =^..^=
    • copiman
      • Sep 2011
      • 861
      Thanks habik for taking the time to post this. I come here for support and try to give support when I can. Posts like yours helps everyone.
