Just FYI.
Found something interesting when using ADF and or your machine starts to freeze or you can't cancel a job unless you do U906 or reboot.
Look for trapped ADF wire harness or broken cable or something of that nature. Mine got pinched so it was easier to spot. If it would brake without being seen the point of breakage it would take me a lot longer.
Those codes correspond to MFP board so signalling corrupt.
Hope this helps scratching heads..
