Can't close the top door , toner cams out of sync
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Misc] Can't close the top door , toner cams out of sync
    SP C5350 The customer complaint was can"t close the top door after adding toner. The drive cams on the left side seem to be 180 degrees out of sync so the metal safty arms don't drop allowing the door to close. It is also very hard to get the toners in and out. I just got a service manual and there is not even an section on this so any help you can give will be great.
    Mark
  • Scottb
    • Apr 2013
    • 306
    Re: Can't close the top door , toner cams out of sync
    double check to make sure that they have the correct toner supplied....i chased my tail on a similar machine, before I noticed, that the wrong toner was installed
      • 23008
      If it really is out of sync, I can forward to you a document on the Gemini modifications. There is a section covering the replacement of the toner cams. =^..^=
