FS-1120D, grey background.
  • Hansoon
    • Sep 2007
    • 3391
    Since I'm a KonicaMinolta guy I do not have experience with Kyocera printers. Customer has a FS-1120D with 75K on the clock having a slight gray background. Since the drum has a lot of grooves I'm going to replace that anyway but would like to know what would be advisable to replace at the same time as well.
    Hans
  • drazen7777
    • Sep 2010
    • 40
    Re: FS-1120D, grey background.
    Hy
    background could be from non oem toner replace developer unit and check feed rollers.
    Sent from my SM-G935F using Tapatalk
    Technician -- a person who fixes the mistakes made by engineers.
      • 23010
      Primary charge is the biggest flaw in the tabletop printers. Often just changing the primary is enough. But if you are seeing wear on the drum, yes, replace the drum/charge assembly. Feed rollers are rated for 120K but rarely make it. At 75K your rollers could be toast. =^..^=
      • copier parts n.ireland
        • Nov 2016
        • 41
        theres a firmware tech bulletin on this,upgrade firmware,while powering up from sleep mode dev bias voltage was out,have had a lot of compatible toners
        also causing background,hence new dev unit or vacum out,if 75k maintenance kit develeper and drum change as they are changed around 100k anyway.
        • Hansoon
          • Sep 2007
          • 3391
          Thanks but I don't get it. OK, English is not my native language but still.......
          When I get the MK-160 Maintenance kit does it contain a drum unit and a developing unit and has the latter developer in it already? With other words, do I need more to cover the grey background issue?
          ..... and Cat you're right. The feed rollers look like a polished mirror. Time for KonicaMinolta tires.
          Hans
            • 23010
            Kyocera monochrome printers are monocomponent. The developing unit will be empty. You run a simulation to fill it with toner. Don't be surprised if you have to install another toner. The dev will suck up most of a toner cartridge. =^..^=
