Kyocera Taskalfa 5501i Water effect
  • barber782
    • Aug 2011
    • 286
    Hi guys,
    Got a strange image quality issue on a taskalfa 5501i. When you print an image or solid background you can see a almost wavy watery kind of effect. Cant think of another way to describe it.
    Already checked and clean drum and charge roller assembly, Replaced dev unit.
    Any suggestions would be great.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: Kyocera Taskalfa 5501i Water effect
    Without samples it sounds like the charge roller dots. You don't see it in regular text images. Print your 089 samples.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23009
      The U089 Sample Set quite often does not show all quality issues. You'll need an image with 70% fill or greater to see the little ovals. Is it like this?:
      AlphardII black developing3.JPGAlphardII black developing1.JPGAlphardII black developing2.jpg
      This problem is caused by the developing unit.
      • copier parts n.ireland
        • Nov 2016
        • 41
        new develeper has fixed every time so far for me,i have started installing cassette heaters on all utax copiers now as i heard this can stop further problems like this.
