250ci light on side in color only
  • copiman
    • Sep 2011
    • 861
    Hello all. I need some help on this one. Late yesterday I responded to a call and had little time to solve. I will be going back today. The issue is when printing in color, the front side, closest to the front of the machine, prints light on colors. Black seems fine. I ran (i think U83) to get some samples and I can't quite tell if I see it in them. Has anyone ran into this before? Full PM was done about 10k ago. I have not had a lot of exposure to Kyoceras so any help in troubleshooting this would be much appreciated for I am on my own on this one. Talked with tech support and did not get anywhere.
    I did drum refresh. Also did dev refresh 3 times. Color calibration 3 times.
  • TECHKYO
    • Aug 2016
    • 15
    Re: 250ci light on side in color only
    as i understand the problem related to laser unit , you need to clean laser unit + polygon motor and it will solve your problem
    • copiman
      • Sep 2011
      • 861
      I take it you mean to remove laser unit from machine and open it up to clean the polygon motor?
      • Kyo fan
        • Dec 2013
        • 368
        Exactly, or you could replace it with another one.
        • Tonerkiller
          • Oct 2012
          • 668
          Run a color belt to see what you actually have first
          • copiman
            • Sep 2011
            • 861
            I did run one but they only had letter paper. I will go back today and run 11x17 which I think would give me better results. The good thing is this issue is not an emergency which gives me time to learn more about it. When I spoke with tech support they said U089 outputs would tell you if it was a drum issue or a dev issue. They may have told us that in class but that was a few years ago and my exposure to kyocera is minimal to date. If they were correct and you know what they were talking about I would be appreciated if you could elaborate on it. I will post the outputs later today which may help. Thanks again.
            • copiman
              • Sep 2011
              • 861
              Here is the printout. It looks distorted to me on my computer so it may not show correctly. I had several people look at it and they were consistent in that the Black and Magenta was lite on left side. I think Cyan is to but not like Black and Cyan. I'm talking about the big shaded areas, not the small solid bars.doc20161215140004.pdf
              • wragsdale
                • Jul 2014
                • 188
                I'd suggest scanning again without compression. What can be seen from your sample can't really be trusted to be image quality issues vs compression artifacts.
                  • 23009
                  If the image quality problem is as subtle as the scan implies, I think I might start with cleaning the laser slit glasses. It is possible that there is toner or dust in the laser, and it's not that difficult to remove and clean.
                  • copiman
                    • Sep 2011
                    • 861
                    Tried it this morning. Still looks bad.
                    • copiman
                      • Sep 2011
                      • 861
                      I pulled one from a machine at the shop. When you say clean the motor, do you go in from the top or the bottom? The top is sealed. I'm sure both would work but I thought I would ask since you have done this before.
                      • copier parts n.ireland
                        • Nov 2016
                        • 41
                        have you tried replacing the magenta and black develeper units,this looks like problems i have seen on other kyocera models
                        • copiman
                          • Sep 2011
                          • 861
                          Not yet. I am going back this week with a laser unit from a shop machine and try that first. If that doesn't work I will look at dev units. All dev units are new though. Although I'm new to Kyocera I just don't know if 2 or more dev units would be bad out of PM kit. But again I'm new.
                          • copiman
                            • Sep 2011
                            • 861
                            Pulled laser from shop machine. Cleaned it up and installed in on Machine in field. Works great.
                            I did open the bad one from field machine when I got back to shop. It was obvious the problem was polygon mirror motor needed cleaning.
                            Thanks everyone for you help.
                            • tmaged
                              Owner/Service Manager
                              • Oct 2008
                              • 1887
                              The trail edge of the polygon motor will get dust built up resulting in what you experienced, even if they're sealed relatively well.
                              It's always light on the front frame side as the polygon must spin counterclockwise.
                              I've cleaned quite a few 5500i & 6500i's as well.
                              Hope that helps !
                              -Tony
                              www.dtios.com
                              Become a fan on Facebook
