FS-1120D, going crazy?
  • Hansoon
    • Sep 2007
    • 3391
    I have no experience with these machines since I'm an Indy doing more or less exclusively KonicaMinolta. One of my customers has this little jewel going berserk. Judging from the take up roller it has around 30k on the clock. Led's are flashing continuously a cycle as follows:
    both green>
    all orange>
    both green + attention + toner + paper in orange>
    both green + attention + jam in orange
    and so on.....
    There's definitely no paper jam and all sensor flags looks physically OK. Tonerbox feels light but not completely empty. What's wrong? Corrupted electronics? Firmware?
    Any help please.
    Hans
    • 23010
    Re: FS-1120D, going crazy?
    We don't sell the FS-1120D here in the US, but the FS-1300D looks a lot like it. Here is the Code Conversion Table.
    If there is a network card on it, the simplest way to decode these errors is access the Command Center (web interface). =^..^=
    • Hansoon
      • Sep 2007
      • 3391
      Thanks Cat. No Network card.
      What do you mean with Code Conversion Table? I have no service manual only the parts manual.
      Hans
        • 23010
        You'll get the all orange which means it's going to start the sequence. The LEDs go blank for 0.8 seconds, then blink the first digit, blank, then blink the second digit, blank, then blink the third digit, blank, then blink the fourth digit, blank, then all orange, and the sequence repeats ... forever ... or until you fix it. Once you have all four digits you'll have a traditional (4) digit Kyocera C code.
        It all comes down to them not designing a screen onto the printer. There is no way to display an error message. Samsung does the same blinking of LEDs BS, but wrote a utility that you can install on your PC that communicates via USB, so you can get diagnostic codes in a window on your PC. Kyocera never wrote that utility. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2033
          It's complicated. Look at the chart. Each light indicator has a number associated with it. So find your pattern and your code my be (Example 0129)
          Let me know what you think it is and I'll look up the code for you.
          • Hansoon
            • Sep 2007
            • 3391
            Its code 7990 and I found out that it indicates an overflow of the waste toner compartment. Removed all toner out of it and the machine is up again with even a good printing quality.
            Thanks for your kind help guys.
            One question remains: I can get a config page but not a page with the total page counter. How to obtain that please?
            Hans
            • Hansoon
              • Sep 2007
              • 3391
              OK, got it. After finding my reading glasses discovered that it says 71k under Page Information. lol
              Thanks guys.
              Hans
                • 23010
                For future reference, to get the Status Page press GO to awaken the printer from sleep mode > hold GO until Ready and Data lights blink > a Status page will be printed. =^..^=
                • Hansoon
                  • Sep 2007
                  • 3391
                  One more question please: What is the rated life expectancy for A) the drum unit and B) the developing unit?
                  Hans
                    • 23010
                    Hans
                    100K each, that includes the fuser also. =^..^=
                    • Hansoon
                      • Sep 2007
                      • 3391
                      Hey Cat, just discovered in my Spam Bin your previous message. Thank you very much for your kind support!
                      Than its a bit early for the waste toner compartment to be full with 71K, isn't it?
                      Hans
                        • 23010
                        Yes and no.
                        As you know, waste toner is a consistent percentage of the toner usage, based on 5% average fill. Let's hypothesize that they're actually averaging 7.5% average fill. The drum cavity would fill in, oh say ... 75K prints.
                        • Hansoon
                          • Sep 2007
                          • 3391
                          Guys does the drum unit DK-150 need a manual calibration or does the machine somehow recognizes the new unit and starts it own procedure accordingly?
                          Hans
                            • 23010
                            It's chipped. The machine knows right away when you install the new one. =^..^=
                            • Hansoon
                              • Sep 2007
                              • 3391
                              Thanks Cat, good night.
                              Hans
