KM4050 dual fax option installed recognized but wont receive and no choice to send
  • Biz2000
    • Aug 2013
    • 13
    this km4050 has a second fax kit and the copier recognizes it and two fax numbers are entered for port 1 and port 2, but on the fax screen where the on hook button is there is no choice to send from two numbers, and the on hook only applies to port 1. also when i try faxing to port 2's phone number the fax never comes through and never gets fax tone. and yes i did swap the fax kits and they both work in the port 1 slot.
    i am out of ideas. the only thing that is possible is that port 2 is bad in that it recognizes the port 2 fax kit but there is no dial tone or there is some setting i dont know about that is preventing me from seeing the second fax line active on the fax screen. I sure could use a bit of help. thanks.
    Ktech
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    Re: KM4050 dual fax option installed recognized but wont receive and no choice to sen
    It's been a while, but I recall setting one up as incoming & one as outgoing only. I believe it was through the web page that I adjusted the settings.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23008
      You will only be able Tx from one of the cards, you're choice. You can Rx from both cards.
      This topic came up where two companies in the same building both put up half the money to buy the MFP. They wanted fax card #1 for company #1 and fax card #2 for company #2. That's fine for Rx, but for sending only one can send. That's it. You can program multiple TTI information selections, so you can make it appear to come from company #1 or company #2. It made the calculation of the phone bill a little more complicated.
      • Biz2000
        • Aug 2013
        • 13
        thank you very much for stopping by and helping me with that information. I dont see these much and after my diagnosis I was afraid that was the case, but its hard to believe they would not design the copier to allow the user to take advantage of a "second" fax kit, especially for that much money...oh well thats the way the cookie crumbles.
        Thanks again, ktech
        • darry1322
          • Oct 2010
          • 817
          I think the idea behind it was that a busy office that sends a lot of faxes would still be able to receive while sending.
          • copydocinc
            • Mar 2015
            • 263
            In maintenance mode 698 choose all, for ability to initialize both ports for faxing.
            Then go to maintenance mode 600 to initialize.
