KM-5050 CFA10 error after boot
  • wachman
    • Apr 2014
    • 50
    believe that this is a hard drive error but not sure as it is reporting an error on the hot plug??? what to do with this error..... any help is appreicated
    • 22930
    Re: KM-5050 CFA10 error after boot
    I think I'd replace the HDD. =^.^=
    • wachman
      • Apr 2014
      • 50
      Thanks for the reply!! I will get that done
      • quitech
        • 82
        Did you format the hard disc? if no, enter the program use 24 to format it. hope it will also help. good luck
        • wachman
          • Apr 2014
          • 50
          A new hard drive fixed the issue Thanks For your Help!
          hard drive was formatted on boot up by the copier. I did still re format after that but don't think it was necessary.
            • 22930
            It does run immediately after the new HDD is installed, but I format it anyway.
            Congratulations on your success. =^..^=
