Common Developer Issue with Kyocera Taskalfa 3051ci
  • Kyo fan
    • Dec 2013
    • 368
    Re: Common Developer Issue with Kyocera Taskalfa 3051ci
    Thanks for updates. I was wondering is it possible to put something next to this black roller to fill this gap and hopefully save some time and money.
      • 23008
      The new developer spacers are from the 6551/7551 developing unit. They have bearings unlike the original. And most likely it's the aluminum shaft that wears as much or more than the spacers. =^..^=
      • daveh12
        • Jul 2012
        • 157
        Originally posted by Ropariva
        Last week I came across a machine with these symptoms for the first time since following this thread.
        I'm able to confirm that the thin black roller that correctly spaces the magnetic roller from the drum was worn in the centre at the end corresponding with the quality problem.
        The replacement developer unit has obviously been beefed up in this area and the this black roller has now been replaced by a much thicker white nylon roller.
        It's a shame that we are unable to purchase these rollers as a spare part [emoji53]
        Thanks for the update.
