False waste toner full, New boxes
  • Geo
    • 662
    Hi All
    We have been getting calls for false full waste toner tanks across the entire new line (B/W and Color). All have low clicks. We are following TB G128 , Removing and reinstalling the waste tank seems to turn off the message.. Has anybody else run into this issue?
  • Jammed
    • Jun 2015
    • 33
    Re: False waste toner full, New boxes
    I don't know what models you have...but, Usually I have seen toner lumping or clogging withing the dump tubes. I think on the Mitas, the toner auger shaft gets forced back and actuates a switch on the rear frame.?? Or the tank is weighted? Increase weight spring tension? or a spring adjustment? I've stuck my vacuum onto the spouts and cleared most of the clumping. We are close to the ocean here and have a lot of humidity. I tell all my customers to shake the new cartridges before installing. That's probably not much help. ..Maybe the looking glass in the tank gets clouded? I use brillianize on the waste tanks to keep the static down.. Cut more space around the sensor hole area?.. Not sure. Good luck.
    • darry1322
      • Oct 2010
      • 817
      Have you tried running the calibration? We haven't had any issues yet. We do remove the waste toner cartridge before moving the machines.
      Waste toner box threshold level setting procedure
      1. Open the waste toner box cover and detach it.
      2. Select maintenance mode U155 and close the waste toner box cover.
      3. Select [Calibration] and confirm [None] indicated next to [Waste Toner]. Press the [Start] key.
      4. Insert the empty waste toner box (Empty), close the waste toner box cover.
      5. Select [Calibration] and confirm [Empty] indicated next to [Waste Toner]. Press the [Start] key.
      6. Remove the empty waste toner box (Empty) and install it. Close the waste toner box cover.
      7. Renew the value of [None/Empty] side, make sure the [OK] display of [Execute] side.
      *: If numbers (error code) is indicated next to [Execute], redo from the first step.
      (If the detected waste toner box weight fluctuates(box installed/not installed), an error is indicated)
      • Geo
        • 662
        Hi darry1322
        To my chagrin I was not aware of MM 155 and apparently T.S. is not aware of this procedure either..
        Moving forward I will take a two step approach, do MM155 and remove the tank instead of just replacing the packing material.
        Thanks Much...
        P.S. Thanks for the detailed steps...We all know how clear some of the instructions are..
        • darry1322
          • Oct 2010
          • 817
          Maybe it'll help. We haven't had any issues yet so I haven't tried it myself.
          I will point out that we just remove the bottle, we don't run MM155. I saw it in the manual and figured MM155 might resolve issues if we had any in the future.
          • Geo
            • 662
            Hi Jammed.
            In these new boxes they are not using an optical sensor (seems to be a weight sensor), however the previous generation did.
            Thanks for giving us good tips and check points for all boxes....
            Thanks Much.
            • The_Murph
              • Mar 2016
              • 96
              Howdy!
              I just did the classroom training and did some in-depth troubleshooting on this issue. Basically from the machine rear you can see the waste chute, drive, etc. The entire waste system can be removed, we found that the spring in the downchute gets bound up and doesn't slide freely, causing waste to build up in front of the td sensor that reads the waste full condition.
              Remove the waste assembly, reseat assembly taking care to ensure that the spring moves freely, should correct your issue.
              Big Dan
              If you phrase your inquiry properly, you will get the answers you seek...
              Good Luck ... You'll need it! HAHAHA!
              ~Big Dan~
              • Athlontini
                • Jun 2012
                • 269
                Also remember to remove the WTBs before transporting these machines, Kyocera should have a bulletin out about it by now.
                • tmaged
                  Owner/Service Manager
                  • 1870
                  G127 is the bulletin that addresses this (8/2016).
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • Tulsa
                    • May 2014
                    • 20
                    Guys, It appears that I am missing something. Could you tell me which models that you are discussing? We have had a couple of issues with waste toner filling up too fast, combined with eating the toner out of the cartridge in less than 4,000 copies on a on a new 5002. Was wondering if there may be some commonality here. The only clue that I was able to glean was "new boxes" and G-127 on a bulletin from (8/16). But could not find that either.
                    Looking for a model number please.
                    Thanks for your help, and great input on your topic.
                    • wragsdale
                      • Jul 2014
                      • 188
                      The applicable models would be any of the x2i or x2ci series, 5002i included. To find the bulletin, you would need to search the service portal (Astea), and not the KDA accessible documents.
                      • Tulsa
                        • May 2014
                        • 20
                        thank you so much
                        • The_Murph
                          • Mar 2016
                          • 96
                          @Tulsa ... the waste system is the same, its all run from a unit in the machine rear. If you pull the rear cover you'll see the waste system, on the right side about 2/3 down you'll see the clear collection chute and a plastic/rubber tube attached to it. Inside the tube is an agitator spring that gets bound up. If you remove the system and reseat the spring/tube, this should correct your "full" waste box issue. PM me if you need more info.
                          QA G128 points out the clear downchute the tube/spring attaches to. get in there and I think you'll understand what I'm saying...
                          ~Big Dan~
                          • The_Murph
                            • Mar 2016
                            • 96
                            Hey Y'all,
                            The bulletin in question "G127" is useful for preventing this issue, however, if you have already screwed up your device, follow my instructions or PM me and we can get you to the solution. I specifically troubleshot this very issue with my instructor in Dallas (he's also my Regional Tech Rep so we worked on some of his dealer issues and this was the #1 issue.), I believe there will be a resolution posted at some point for this, however in the mean time, I may be it...
                            ~Big Dan~
                            • tmaged
                              • 1870
                              If it's a false waste toner full, that is what the bulletin addresses & what Murph is talking about. But if it's pulling toner & actually filling the bottle, that's a different issue.
                              Generally a high voltage leak is the only thing that would cause it to cycle toner right through to the waste bottle.
                              Hope that helps !
                              -Tony
                              www.dtios.com
