FS-9530
  • Jammed
    • Jun 2015
    • 33
    FS-9530
    This printer is giving us fits. Only tray 3 dog ears.... All new PF rollers, only 80K on box, Swapped out trays, swapped out PF assy's. Cleaned and waxed all left door guides, pickers, etc... Dog ears go away for a day. Come back hard. Front top corner folds backwards over the paper before the fuser. Special label paper is used 100%. Hard fold. Trays are set for special paper. Has the added two tray pedestal not the LCT style. No finisher. Tray 3 is being difficult...Been there, done that anyone? Thanks... -Steve
    • 23008
    Re: FS-9530
    Are you getting J12's? This is worth a try: On left door idler rollers install two pressure springs in the outer positions on each shaft (2BL06340).
    • Kyo fan
      • Dec 2013
      • 368
      Re: FS-9530
      There were 2 bulletins regarding similar jams with paper folds.
      First was shape change of the left cover 2:
      Second was the shape change of retard pulley release lever on paper feed assy:
      New name: + LEVER,RETARD PULLEY RELEASE (302FG07281)
      • Jammed
        • Jun 2015
        • 33
        Re: FS-9530 Dog ears fixed
        They were running 81/2 x 11 r special paper. The solve was this. I watched the paper ejecting and noticed it was slightly off center of the eject rollers, only about 2-3 mm. I adjusted the paper position in the tray with the plastic screw and gear cam thingy.. I brought the paper closer to the front of the printer. It tracks straight in the center of the eject rollers now... Problem solved.
