Kyocear 500ci Platen glass copy
  • ameritech
    • 96
    [tach][ATTACH=CONFIG]35772[/ATTACH][ATTACH=CONFIG]35773[/ATTACH]hello all, the bottom of the copy is darker when i make copy from the glass. The left picture is black and white, the right one is color copy. Any help would be great. Thank you.
  • Eresources
    • Nov 2011
    • 37
    Re: Kyocear 500ci Platen glass copy
    Have seen the little black plastic pieces that the scanner carriage runs on, break and cause the mirrors to lose focus and cause a wavy image on the page. There's 4 of them, one in each corner. Maybe ones broken and when the carriage moves it's dragging a bit and causing the mirrors to change angle.
    • tee
      • Aug 2014
      • 79
      If the prints and the copies from the adf are good, then
      I would try setting the target with test chart P/N: 302FZ56990 using code u425 ; then run the chart on the glass using u411.
      • ameritech
        • 96
        Thank you everyone. I will give those a try.
        • ameritech
          • 96
          Thank you for your help. Yes it is the black plastic bushing on the optics itself. It was so small I missed it.
          • Lunatech
            • Oct 2012
            • 177
            Please do not take offense, but did you clean the optics?
              • 22930
              Congratulations on your success. =^..^=
              • Eresources
                • Nov 2011
                • 37
                It's a real bugger of a one to find. It took me close to 2 hours the first time I saw this happen. In the last 4 years I've had it happen maybe half a dozen times. Still can't work out how they break.
                • nenovvv
                  Hi,
                  I need of P/N: 302FZ56990 to calibrate my Kyocera FS3040.
                  I was change a scanner and now I can't copy in Auto Density, only manual density.
                  Help me.
                  Regards
