TaskAlpha 3550idn jam code 501 cassette one
  • allstar59
    • Oct 2012
    • 64
    I have two 3550's with the same problem and I really need some suggestions. The problem happens only with multiple copies, single or double sided, only cassette one. The bypass and the extra tray two are fine. It happens every four or five copies jam 501. There's a piece of paper about half fed from the tray and one part way through the fuser. I've replaced the feed, pick up and separation rollers, the entire separation roller assembly because it was the old style with the long arms, and also the paper feed drive assembly which contains the feed clutch. I think I'm going to order the entire cassette but if that doesn't do it I'm stuck. Any help would be great. Thanks, Jim
  • Kyo fan
    • Dec 2013
    • 368
    Re: TaskAlpha 3550idn jam code 501 cassette one
    The only thing left for you is to put some good quality paper in. No modification will help if the paper is cheap.
      • 23008
      Just tray #1 or both trays? =^..^=
      • Geo
        • 662
        The reg roller clutch may be experiencing a run on condition or not stopping immediately after power off. As we all know , these clutches are not the best in the world.
        Good luck...
        • daveh12
          • Jul 2012
          • 157
          If it's only tray 1 and not tray 2, first thing I'd do is swap pick assemblies to see if the problem follows, likewise with the cassettes to try and see from where the problem is originating. Try this before digging out feed clutches etc.
          • The_Murph
            • 96
            I've had the lifter gear for cass 1 break. this made the paper jam as the cass was trying to lift during printing ops. you should be able to clearly see it with the cassette removed. It happens when users rifle the cassette into the machine. be forewarned, its a major undertaking if replacement is needed, not for the faint of heart or those lacking confidence in their abilities.
            If you phrase your inquiry properly, you will get the answers you seek...
            Good Luck ... You'll need it! HAHAHA!
            ~Big Dan~
