kmc3225
  • Franky Tan
    kmc3225
    Hi ! i have a problem about this color machine, cyan or magnenta toner drop down with a few dots. after cleaning and color calibration about 10k copied the problem seem come back. is it related setting ?Please give solution .But one thing is developer unit and drum unit life span is not due . thanks
  • Raymondd
    • Jan 2008
    • 108
    Franky Tan,
    Is this a KM/C3225E or not?
    Are the colors washed out?
    • Franky Tan
      Originally posted by Raymondd
      Franky Tan,
      Yes.this is model. the color is ok only color toner drop down intermiten.
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        Dev,drums and fusers 300k
        Yep and i'm elvis - they never reach their life and they always get replaced early because they fail!
        Spots on the copies are more than likely from the drum units. You can clean them but whats the point when its under warranty - kyocera's fault for a bad design.
        dev units fail because of the collar breaking.
        Fusers fail with a noise or codes or both.
        makes you laugh when the units are all complete units and you can't order individual parts because of "kyocera quailty control"
        Incontinentia Buttocks
        • Franky Tan
          THANKYOU .
          • techman
            • Dec 2007
            • 49
            check the collars on the dev units there is a defect on some of the older units, or try pulling the transfer unit out and see if there is any pieces of paper near the cleaning section of the transfer unit causing toner to drop on the drum unit have had this happen to me a time or two.
