Kyocera - Fleet Services
  • thinkink
    • Apr 2016
    • 62
    #61
    Re: Kyocera - Fleet Services
    Originally posted by Necrocannibal
    I did this and it didn't allow me to register it, after I called the last dealer they deleted it out of their KFS and it registered fine.
    Sent from my SM-N986U using Tapatalk
    Does someone know if a Kyocera device still registered in KFS from previous dealer, will also not show up when using Netgateway?
    • Santander
      • May 2009
      • 768
      #62
      Yes, it does not matter if it is going through a gateway or is direct. The serial number is still registered to another dealer and will prevent you from registering the device. Until the previous dealer deletes the device from their database, you can not register the device to your account.
      • tmaged
        Owner/Service Manager
        • 1873
        #63
        What model are you trying to connect ? Anyting in about the last 6-8 years will connect direct.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • thinkink
          • Apr 2016
          • 62
          #64
          Connecting a 3252ci, yes it does connect directly, but we having been getting these off lease and putting them back out. Quite a few are still registered and it's a real pain to figure out where they came from and get them unregistered. Just wanted to make sure Netgateway also used the serial number.
          thank you
          • tmaged
            • 1873
            #65
            thank you
            Unfortunately there's no way around it. Most dealers aren't too bad, but a couple of them I've had to call 3-4 times to get it done. It's not in Kyocera's SOP to remove them, so calling the originating dealer is the only way to accomplish it.
            Hope that helps !
            -Tony
            www.dtios.com
            • Froota
              Field service tech.
              • 129
              #66
              IMO you can disconnect the device from KFS in service mode. after that you can re-connect with KFS.
              But KFS is a Kyocera service platform, so I assume it's better to contact Kyocera instead of the old dealer, not?
              • tmaged
                • 1873
                #67
                Clearing the machine with either 520 or RSAdmin only removes the KFS connection for the machine. If it's an offlease machine and is registered to a previous dealer, they have to remove it from their KFS account. Kyocera America will not remove a machine from an account. The dealer that it's registered to is the only one that can remove it. Kyocera Europe might have a different operating procedure.
                Hope that helps !
                -Tony
                www.dtios.com
