CS 5500 with a J6511
  • Scottb
    • Apr 2013
    • 308
    Hello all so I have this finisher wadding up paper when in staple mode J6511. I have replaced the metal sensor bracket, the side guides, and the black plastic guide with the new spring and white pieces, and also the clear guide. It worked fine for me but the next day they were again having issues, so unless there are any other updates that I have missed I am at a loss.
  • Santander
    • May 2009
    • 768
    Re: CS 5500 with a J6511
    Does it only occur when using the staple mode? The J6511 [1000 sheet finisher] just means the bundle was not ejected. Is the job stapled properly or not at all? Had one a while ago were there was a staple stuck at the end of the cartridge and would occasionally catch the edge of the stack causing a jam. Take a look at the stapling assembly, it may not be operating properly.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1890
      I've traced almost all finisher jams back to the AK-730 exit unit. Make sure it has bearing & not brass bushings. The bushings slow the page down, even if you clean them all, so you'll get a variety of finisher jams. Believe me, I did everything possible to figure this out.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Scottb
        • Apr 2013
        • 308
        oh it is stapled just not in the right place usually the paper folds up and then its stapled, I will look when I go back out. Thanks for the reply.
        • Scottb
          • Apr 2013
          • 308
          Thanks for the reply,
          If I had to guess it has the bushings, but I will look next time out. I hate to ask but what bushing number is the replacement.
            • 23010
            There is not retrofit. It's an assembly. =^..^=
            • tmaged
              • Oct 2008
              • 1890
              303NB94175 is the unit number.
              Hope that helps !
              -Tony
              www.dtios.com
              • Scottb
                • Apr 2013
                • 308
                Doh! I was afraid of that.
                • Scottb
                  • Apr 2013
                  • 308
                  Thanks I went on and ordered a couple
                  • JVergin
                    Service Tech / IT Rep
                    • 216
                    We had this at one place intermittently. We could never get it to jam while we were on site. The customer had cheap paper so we decided to try turning the paper to landscape orientation. The customer upgraded their machine in the next few months but never had another issue with J6511 jams and paper folding over onto itself before stapling.
                    My guess is the paper had enough curl to either fold over onto itself or hit something when being fed back into the stack to be stapled.
                    • Scottb
                      • Apr 2013
                      • 308
                      Okay so both relay exit sections had the bronze bushings, and now both are replaced with new style with bearings. Thanks for everyone's help.
