KM2550
  • tcypy1961
    • 773
    [Misc] KM2550
    Registration on top drawer is off consistently feeding too fast, 2nd drawer is correct. Fuser is also causing a cq issue. Could there be a relationship between the fuser and the registration problem???
    Thanks!!!
  • Tonerkiller
    • Oct 2012
    • 668
    Re: KM2550
    Is the paper weight set properly?
      • 23008
      Re: KM2550
      Do you have any samples marked with the feed direction? Have you looked at tray adjustments and image adjustments? That's what I would do. =^..^=
      • qtech
        • Jul 2009
        • 41
        Re: KM2550
        I have replaced many paper feed clutches on this series (1620/1650/2050/2550). Check Fuser Roller for contamination, order Fuser Right Assy or entire Fuser Assy to fix.
        • tcypy1961
          • 773
          Re: KM2550
          Thanks for the replies!!!! This copier was used in another location where these problems were not occurring. What I'm really asking is could there be a connection between the fuser and this problem with registration; however the fact that it only happens with the top drawer will have me ck the paper weight, all other settings are accurate.
          Thanks again!!!
          • darry1322
            • Oct 2010
            • 817
            Re: KM2550
            No. The paper registers to the image well before the fuser.
            • Lunatech
              • Oct 2012
              • 208
              Re: KM2550
              One thing that I used to see in some of the old Canons is the sensor flag for the number one drawer would wear down and cause the registration to be off.
              Some techs would just adjust the registration not caring that it was only cassette one that was the problem.
              After having been adjusted the machine would then be off on all the other cassettes and sometimes cause jamming due to the
              registration being so far off, sometimes in the fuser causing it to be soiled and or damaged.
              FWIW
