Kyocera 8001 jam 4913 4915 4918
  • nathicana
    • Aug 2008
    • 335
    This Kyocera 8001 has jam codes 4913 4915 4918 bridge conveying sensor 1 not turning off.
    Paper stops just entering the fuser, rolled up at finisher entrance, at primary feed and in conveying unit. Nothing in bridge area.
    Replaced drawer of bridge section and the drive unit behind the drawer which has BRCS1 and BRCS2 sensors.
    Problem is very intermittent, can happen single or two sided. Machine has 1.5 million copies.
    The firmware is up to date, fuser recently replaced. Has anyone had 49xx codes on the 6500/6501/8000/8001 type machines?
    • 23009
    Re: Kyocera 8001 jam 4913 4915 4918
    Oh yeah, I've been down that road. Take a look at the exit sensor flag. At 1.5M you'll have a very noticeable flat spot on the top surface of the flag.
    I went down that same road. I replaced the bridge sensors, flags, rollers, bushings, one-way bearings ... and none of it made any difference. Do I have a photo?:
    • Geo
      • 662
      Hi
      While your taking care of the bridge unit issues, check the de curler flag and sensor...The sensor tends to get knocked out of place and a new style flag was released. The flag shaft is slightly shorter to allow a e/c clip to be used to hold it in place. Not sure of ser # cutoff.
      Have fun
      • nathicana
        • Aug 2008
        • 335
        [ATTACH=CONFIG]36681[/ATTACH][ATTACH=CONFIG]36682[/ATTACH][ATTACH=CONFIG]36683[/ATTACH][ATTACH=CONFIG]36684[/ATTACH]
        Thank you so much for the prompt reply.
        This looks like middle guide from the exit unit just after the fixing area 302K994662. We will replace.
        I wanted to make sure it wasn't the relay exit unit at left end of the machine.
          • 23009
          That will do the trick.
          Usually I just order the flag (302K928121) and return spring (302K928190).
          The photo is of a short term MacGuyver that got the machine running until the part came in. =^..^=
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1890
            The one with the paper clip was sheer brilliance !
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
              • 23009
              Thanks. AFAIK that one is still in the field passing paper:
              If you work on Lexmark you'll understand my inspiration. =^..^=
              • habik
                • 2013
                [ATTACH=CONFIG]36690[/ATTACH]
                Quality BC.
                I am using mylars on both sides. They seem to do trick plus its self adhesive so it is sometimes quicker, like in the drum area of finisher.
                Firmwares HERE
                • nathicana
                  • Aug 2008
                  • 335
                  20170525_112936.jpgThanks for the help in getting this machine running!
                  • Geo
                    • 662
                    Hi Blackcat
                    The universal multi-use paperclip is a fantastic idea ...I used it yesterday, and to secure it to the flag I used instant light activated super glue 5 Second Fix As Seen On TV UV Gluel Light Repair Tool Liquid Plastic Weld Pen | eBay . This seems to work well and the advantage is you can hold something in place and instantly bond it.
                      • 23009
                      I'm glad it worked for you. It's acronym on the paperwork is SPC or LPC depending on the size of the clip. =^..^=
                        • 23009
                        Originally posted by Geo
                        Hi Blackcat
                        I have a bunch of these (Lazer Bond 3 Second Fix - UV Light Repair Tool Liquid Plastic Weld Quick Welder | eBay I was quite disappointed with. it seems to adhere at first, instantly, but later on just falls off. I'll have to try the one you mentioned.
                        Overall I've had much better results with house brand 5 minute epoxy.
                        • Geo
                          • 662
                          I use the UV just to set the broken piece/part in place , then follow up with the 5 minute epoxy and if appropriate , LPC or SPC whole or piece beaded in the epoxy for reinforcement.
                          • Tonerbreath
                            • Sep 2018
                            • 2
                            Thanks for the post. Flag was worn just as you said. Picture tells the story
                              • 23009
                              I'm glad it worked for you. =^..^=
