Charge Roller Change (Finally !)
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1898
    We ordered an MC-8705 and it subbed out to an MC-8720. The new charge rollers have the updated glue to eliminate the bumps & a spiral cleaner to eliminate the lines.
    It only took them 6 years to fix it. Hopefully this does it. I asume the MC-6705 will be updated as well. I did notice they also did away with the gears in the end of the charge roller.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Charge Roller Change (Finally !)
    That's good to know...I know our Tech Rep was looking into that for us on whether they were gonna retrofit them for the older machines...I'm glad they did this....I dunno how many of the things I've been cleaning lately...especially at schools with cheap ass paper....it's a frigging blizzard of paper dust in those things....
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • Geo
      • 662
      Originally posted by tmaged
      We ordered an MC-8705 and it subbed out to an MC-8720. The new charger rollers are supposed to have the updated glue to eliminate the bumps & a spiral cleaner to eliminate the lines.
      Hi
      This may be a silly question, but how did you determine or discover that glue is the problem ?
      • tmaged
        • Oct 2008
        • 1898
        By taste, how else could you determine it ?
        just kidding, there was a bulletin for it, but when it came out, I thought
        to myself, why not fix the cleaning roller also. Apparently they heard me.
        Hope that helps !
        -Tony
        www.dtios.com
          • 23010
          The glue has been a problem since the Alphard 1 first appeared. The symptom I noticed right away was the spider imprints where it would continue to arc from the same spots, Do we dare hope that Kyocera has designed a charge roller that can make yield? =^..^=
          • tmaged
            • Oct 2008
            • 1898
            Since we have a part number, now I was able to bulletin H042. It does in fact reference MC6720 for the mono machines.
            Hope that helps !
            -Tony
            www.dtios.com
            • daveh12
              • Jul 2012
              • 157
              At long last. Thanks [emoji106]
              • Kyo fan
                • Dec 2013
                • 368
                Finally some good news regarding the charge rollers. If they would only take advices from techs...
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  I would've traded better charge rollers for the ability to pull them out of the machine without taking that damn toner contraption off.
                  • tmaged
                    • Oct 2008
                    • 1898
                    If these things work like they're supposed to, you will only need to every 600k.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                      • 23010
                      Many of the older Lexmark printers had primary charge rollers that mounted inside the engine, separate from the imaging unit, and lasted the lifetime of the machine. So it is possible to make durable charge rollers, just not by Kyocera. =^..^=
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        The roller is a quantum leap from the grid/corona wire. I can handle some problems that can be fixed quickly. Kyocera is heads and shoulders above other models regarding logic codes, dimms, hdds and other non mechanical failures
                        • temas
                          • May 2011
                          • 22
                          Hello mate. can you please share link to the service bullettin. i need to convince a customer. i have access to the kyoceraextranet but cant find the bulletin.
                          regards
                          Do not find fault, find a Remedy, anybody can complain.
                          • tmaged
                            • Oct 2008
                            • 1898
                            regards
                            PM me your address & I'll email it to you.
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            • Geo
                              • 662
                              Now if they would only improve feed rollers life...I'm not greedy....300k min. per set would be a nice bare minimum...
