CS-1650
    • 23010
    #16
    Re: CS-1650
    Solved 2 issues:
    1) Loaded 4.11.02 SFU, Ran as Administrator, and changed firewall setting for the rule FTP Allow, to Allow all Services. Connects and scans. The DF doesn't work, but that's the least of my worries.
    2) The second network cable is intermittent. Probably chewed through by the cat (again). Time to make another cable. Maybe that will get me printing.
    3) Tried email, but no dice. It would require a local email server port 25.
    Thanks again.
      • 23010
      #17
      Re: CS-1650
      2) Bad switch port. Swapped ports and we're printing.
      Just to figure out the original misfeeds and replace the drum and I think we're good. Apparently they're in-stock. =^..^=
