Taskalfa 5500i 2Sided-2sided copy option is not displaying in Duplex tab
  • spid3rguy
    • Nov 2011
    • 16
    Dear Kyocera Experts,
    I have recently bought a reconditioned KM Taskalfa 5500i and i just come up with the problem that in "Duplex tab 2sided to 2sided copy option is not displaying up". 1sided to 2 sided is there and i am using the feeder for 1 sided to 2sided.
    Please any help.
    Regards
    Khawar Hayat
    PH: 00923156076007
    • 23010
    Re: Taskalfa 5500i 2Sided-2sided copy option is not displaying in Duplex tab
    Check to see if you have an error condition for the document feeder second side CIS. After the first time the error is displayed that part of the DF will be isolated. This was very common on the Saturn series. =^..^=
    • darry1322
      • Oct 2010
      • 817
      How much memory is showing up installed on the 5500? Early versions of this machine required optional memory upgrade to do 2 sided originals.
      • spid3rguy
        • Nov 2011
        • 16
        Dear there is not error indication everything is alright but nothing in troubleshooting mode that can help. also no help with 021 program or factory reset.
        should i change the adf?
        • spid3rguy
          • Nov 2011
          • 16
          1gb
          • darry1322
            • Oct 2010
            • 817
            Originally posted by spid3rguy
            1gb
            Upgradable to 2 gb. Later versions shipped with 2gb standard for duplex copying with the DP771.
              • 23010
              U906 would have been a better choice. U021 wipes the entire machine to no good purpose. Nothing on the error log? (Not any more.). =^..^=
              • spid3rguy
                • Nov 2011
                • 16
                Ok thnks for the amazing help!@darry and blackcat. Just consult with the Supplier. He also said the same as i have to upgrade from 1gb to 2gb and sure he will send the 1gb stick to me asap.
                Regards
                Khawar
