Have this unit throwing c6050 error. Replaced fuser and still does it. Warms up, comes to ready but throws the code when trying to make a copy or in idle. Wall voltage good. Reseated all connections. Any input greatly appreciated.
Taskalfa 221 c6050
Tags: None
Re: Taskalfa 221 c6050
How good is the wall power? Did you put your multimeter in the hot - neutral for 10 minutes, or do a power quality analysis? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Reading 121 for over 5 minutes. Fuser powers up on start up, but once machine comes to ready, it never turns back on to keep temperature up, just goes into code.
BrianComment
121vac hot to neutral? What about ground to neutral? =^..^=If you'd like a serious answer to your request:
After replacing the fuser did you run Sim 163 to reset any fuser error codes, just replacing the fuser does not automatically reset the error codes. You could also run Sim 198 [turn on] Phase control to have the unit eliminate electrical noise caused by the surrounding environment and the unit itself. Blackcat is also correct in making sure that the neutral to ground is wired properly. A simple cheap outlet tester will let you know if the outlet is wired correctly. The routing of the wiring is also important, after replacing the fuser did you run the unit with the cover off? Simply putting the cover on with improper wire routing can cause a wire crimp or a dislodging of a connector. Hoe this helps.Comment
