Konica Biz-hub 223
  • hummer
    • Jul 2025
    Konica Biz-hub 223
    Does anyone have any info on replacing paper feed / separation tires on this machine. Does the unit need to be pulled first and is it done from the right side of the machine or thru the cassette area? We replaced the developer , drum unit and fuser unit on time required by maintenance, but this got me stomped as we do not have any info on this machine as far as disassembly goes.
    Hummer
    • 23008
    Re: Konica Biz-hub 223
    I suppose a person with small hands might be able to reach in through the cassette port, but I never could. The entire pickup assembly comes out through the right side. That's the way I've done it. Earlier KM's were well known for having the most difficult feed tires to change. When I was in class on this model my lab partner was a newbie, and spent half a day messing around with the feed unit. I've never seen one disassembled that far before (or since). =^..^=
    • copyman
      Owner / Technician
      • Sep 2005
      • 4702
      Actually both paper feed assemblies for tray 1 & 2 are removed from FRONT of machine. Remove paper trays then each feed unit has 2 screws and connectors in front and will come right out.
      Unlike the prior models Bizhub 200/250/350 which only tray 1 was removed from front and tray 2 was removed from side, now both trays on Biz 223 series come out from the front.
      Best to get the service manual and follow the easy instructions.
      • laitang
        • Nov 2012
        • 627
        refer the document
        • copyman
          Owner / Technician
          • Sep 2005
          • 4702
          laitang the instructions you posted are not for the "Konica Minolta Bizhub 223". The Bizhub 223 instructions are attached (3 pages).bizhub423_363_283_223 PF1.pdfbizhub423_363_283_223 PF2.pdfbizhub423_363_283_223 PT1-2.pdf
          • laitang
            • Nov 2012
            • 627
            Originally posted by copyman
            laitang the instructions you posted are not for the "Konica Minolta Bizhub 223". The Bizhub 223 instructions are attached (3 pages).[ATTACH]38254[/ATTACH][ATTACH]38255[/ATTACH][ATTACH]38256[/ATTACH]
            Sorry! I miss, it's toshiba 223, not Bizhub 223
            • hummer
              Thanks Copyman......you made my day. I will do this come Monday
