copystar to TA kyocera
  • craigster
    • Apr 2016
    • 201
    Does anyone remember how to change the the status page to go from copystar to TA kyocera, pretty sure its in service mode! maybe under destination or oem code. the service manual does not explain it well.
    • 23010
    Re: copystar to TA kyocera
    It's called Destination. U265 > Copystar = 66, Kyocera Mita =2, Utax = 11, Olivetti = 12
    But keep in mind that your machine may no longer accept the original badge's toner. =^..^=
    • jewen25
      • Mar 2009
      • 197
      You mean sir if change the distination the toner well not read?
      ERROR HELP ME AND HELP YOU
        • 23010
        I mean that if you change the destination to, say: Utax, the machine will no longer accept Copystar toner.
        • craigster
          • Apr 2016
          • 201
          Awesome! Thank you
          • kyove
            • Apr 2015
            • 62
            One time I change an Olivetti to Kyocera.
            Machine will not recognizes Olivetti toner as original so I put a Kyocera toner.
            Kyocera toner will not enter because a plastic pattern on the bottom of cardtrige will not match.
            I have to disassembly machine and planed plastic theeth that makes the pattern.
            Bye!
            Kyove
