Taskalpa 8002i
  • stevee104
    • Mar 2007
    • 214
    Taskalpa 8002i
    Having jam codes of j2306 on machine, have change out main drive unit which it has new clutches on it
    and also all feed rollers and still a stop jam. Have look om Kyocera website for bulletins and can not
    find anything for this machine but saw one for the 6500i. Its never making it by the feed and separation
    rollers when it jams, tray 4 runs with no problems. Looking at replacing pwb board but wanted to
    see if you guys have had this issue, and when it does feed it doesn't skew.
  • sparkycivic
    • Apr 2017
    • 348
    Re: Taskalpa 8002i
    I dont see Jam 2306 listed in my manual...
    • stevee104
      • Mar 2007
      • 214
      Re: Taskalpa 8002i
      I'm sorry I got the numbers backwards 2603
      • stevee104
        • Mar 2007
        • 214
        Re: Taskalpa 8002i
        I am sorry got numbers backwards should be J2603.
        • sparkycivic
          • Apr 2017
          • 348
          Re: Taskalpa 8002i
          you're changing those parts of the lower "paper feeder" section, right?
          Have you removed the feed unit for tray 3 yet to inspect it's sensors such as lift sensor and paper sensor that are both in the feed unit, and re-seat the rollers?
          Does the leading edge of the paper have any marks or deformation, and exactly how far does the leading edge get?
          Does it work sometimes?
          • stevee104
            • Mar 2007
            • 214
            Re: Taskalpa 8002i
            Had paper feed unit out to replace feed rollers and everything looks good
            paper makes it to the separation roller and stops before it and no marks on paper and yes it does work sometimes,
            have paper out of for now just using tray 4.
              • 23009
              Re: Taskalpa 8002i
              I think I'd monitor the signal to the feed and vertical feed clutch. On KM-8000i I've seen a bad Feed PWB1 that never provided the ground signal for the clutch. =^..^=
              • sparkycivic
                • Apr 2017
                • 348
                Re: Taskalpa 8002i
                how bout that one-way clutch just at the feed roller? I've never seen that one fail, but i haven't been around here all that long...
                • The_Murph
                  • 96
                  Re: Taskalpa 8002i
                  Doesn't the 8002i have a sep tension adjustment for each source, similar to the 6052ci series machines? If so, it could be that the sep tension is slack. That would cause this in the new series... I assume this is cassette specific, have you swapped feed input units or components to see if it follows the unit?
                  If you phrase your inquiry properly, you will get the answers you seek...
                  Good Luck ... You'll need it! HAHAHA!
                  ~Big Dan~
                  • stevee104
                    • Mar 2007
                    • 214
                    Re: Taskalpa 8002i
                    Having swap the paper feed out yet, it is only cassette 3 causing
                    the issue, will be heading back out Thursday to swap our
                    the feed unit being they are different form tray 1 and 2.
                    • The_Murph
                      • 96
                      Re: Taskalpa 8002i
                      Before swapping it out, I would check to ensure that the sep tension is set on the cass 3 mechanism.
                      ~Big Dan~
                      • Geo
                        • 662
                        Re: Taskalpa 8002i
                        Hi
                        I would HIGHLY recommend replacing the entire drive unit assy. We have had problems in the past with unexplained feed/no feed issues from 3 and 4. The drive assy uses the same high quality, well engineered clutches ( sarcasm) that tend to rust or run on .
                        Are we having fun yet?
