2551ci with blank copies
  • T911
    • Jun 2007
    • 628
    originally it had cq problems, rescheduled for maint kit a and b. before i can get back they called in for blank copies and prints. went with kits and sure enough black is blank, i checked my contacts for black, put in the new k dev unit and swapped the drums around but no luck. im not getting any codes but im going back with the toner motor assly and the drive motors for k dev unit and k drum. ideas appreciated.
    • 23008
    Re: 2551ci with blank copies
    Can you tell if the black developing unit is turning? If it's not you find the toner inlet packed solid with unmixed toner. =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      Your train of though, I think, would have some washed out black
      Totally blank would point to laser
      • T911
        • Jun 2007
        • 628
        black dv is turning ill check the inlet and ill also bring the laser.
