5551ci c2840, mission impossible
  • jamman
    • Mar 2013
    • 5
    [Error Code] 5551ci c2840, mission impossible
    replace transfer belt, engine board, inspect harness, engine board to transfer belt. no effect c2840 will not give up. HELP
  • Ropariva
    • 654
    Re: 5551ci c2840, mission impossible
    906?
    • kyove
      • Apr 2015
      • 62
      Hi Jamman,
      Did you check the "PARTS CLN WT UNIT SP"?
      You can find it in part list, Electrical Component 1
      You have to remove Fuser, Transfer Belt, Yellow Developer, Yellow Drum, Left Cover so you can remove the WT Unit.
      Carefully clean it and check the motor.
      Hope this help,
      Kyove
      • pascalb.
        • Aug 2016
        • 47
        hello,
        Check the connector of the transfer belt on the side of the machine.
        sometimes the contacts are twisted.
        Do not lament,
        do not mock,
        do not hate,
        but understand.
