SMB Scanning and Norton 360
  • Geo
    • 662
    Hi Folks
    I am setting up a 3011i for SMB scanning , problem is Norton 360 is blocking the connection (error 1101) . Disabling Norton on the target P.C. ( not a server) allows the scans through...So my question is..Does anybody know exactly how to modify Norton to allow SMB scans through. Tech support tried but was unable to resolve the problem.
    Thanks much.
    Geo
    P.S.
    Happy , healthy and prosperous New Year to all.
  • copier tech
    • 8176
    Re: SMB Scanning and Norton 360
    I would also explain to the customer they dont need to waste their money on antivirus software, Windows has built in antivirus security software.
    • Geo
      • 662
      I Agree, but this came "free" with the ISP.
      • Rpizzle
        • Mar 2014
        • 47
        yeah these can be a nightmare. try allowing the incoming internet connection via ip. works for me although I cant tell you exactly where to do anymore.
          • 30314
          Please go to the Network Security Map in the settings of Norton 360 and make sure that your printer is added as a device and set as Full Trust.
          • KyoServiceManager
            • Oct 2017
            • 30
            Usually for Norton, there is a check box in the exceptions for file and print sharing. If you check that box and save the settings it will usually allow SMB scanning. Occasionally you will have to reboot the PC after making the change.
            "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -Einstein
            • Santander
              • May 2009
              • 768
              The 1101 code indicates the machine cannot find the host. If you are using the host name, Norton by default blocks network discovery, hence blocking the machine from finding the PC. You can either open up network discovery in Norton for private networks or if in a domain for that or make an exception in the rules.
              • copiertec
                • Jan 2016
                • 2211
                Originally posted by Geo
                Hi Folks
                Thanks much.
                Geo
                P.S.
                Let me know what resolves this for you, please. My solution was either to remove it or have the client call their IT dept.
