C7301 TA 4501I
  • brancas
    • Jul 2009
    • 80
    C7301 TA 4501I
    Greetings all. I have a 4501i giving a C7301 error.Checked toner hopper unit motor and developer unit in Maintenance Mode , all was well.I tried original developer unit and toner hopper unit in a working machine and no issues.I replaced toner hopper unit, Front PWB as suggested by Service Manual. No joy. The next step is the Engine PWB. Need some advice as to what else should I check before replacing Engine PWB.
    • 23009
    Re: C7301 TA 4501I
    The machine that I worked on had a bad piezo sensor on the toner hopper. But it sounds like you've covered that possibility. =^..^=
    • craigster
      • Apr 2016
      • 201
      Re: C7301 TA 4501I
      check the connector were the hopper assy plugs into on machine, I had one with a bent pin
      • Geo
        • 662
        Re: C7301 TA 4501I
        After checking the pins , if no joy, try doing MM 021 as a Hail Mary. This once worked for me.
        • brancas
          • Jul 2009
          • 80
          Re: C7301 TA 4501I
          Thanks for all the helpful advice. In the end it really was a bent pin where the toner hopper plugs into. Straighten it back and all is well. Thanks again.
          • Azeem Khkh
            Re: C7301 TA 4501I
            I have same problems in 3500i Koycera Taskalfa. C7301 code appearing. How i open Toner hopper motor . Where is located
            • mickeyc123
              • Apr 2013
              • 18
              Re: C7301 TA 4501I
              remove the toner hopper, remove the toner hopper cover, 3 screws.
              blow the marked sensor with a can of air and reassemble, error should clear.
