Kyocera KM 1650 Registration switch
  • ecoworld
    • 15
    [Jamming] Kyocera KM 1650 Registration switch
    Hi everybody
    Can anyone indicate me where the registration switch is located on the Kyocera KM 1650 machine. I am getting misfeeds and JAM 11 on the machine.
  • habik
    • 2013
    Re: Kyocera KM 1650 Registration switch
    Originally posted by ecoworld
    Hi everybody
    The registration actuator is in the middle just below the silver roller. The actuator sits in white cover and is spring loaded (usually). If the spring on the rear side pops off or is lost, the actuator may be slow to return causing misfeeds. Also check your rollers are not worn and the pick up roller is with the black (updated)ribbed rubber instead of grey.
    Depending on paper you can get 70-120k out of those rollers, usually.
    Sent from portable device using fast cheapset!
    Firmwares HERE
      • 23009
      It looks a lot like this:
      I'm sitting 2 feet away from one.
      • habik
        • 2013
        [ATTACH=CONFIG]38673[/ATTACH]
        Bet you don't use bypass much
        Firmwares HERE
          • 23009
          It's a great place to store extra paper, that's it though. =^..^=
