Taskalfa 255c won't print color
  • TEKK09
    • 142
    Machine says ready to print, and if you touch the 'full color' button, it gives the message that only black is available. Doesn't say anything else. Just that only black is available. I'm trying to find an Operator's Guide online and at Kyocera but no luck yet. Can anyone help please?
    • 23009
    Re: Taskalfa 255c won't print color
    Could it be out of color toner? Or due for color maintenance? =^..^=
    • Santander
      • May 2009
      • 768
      Totally agree with Blsckcat! The machine is set to print/copy only in BW if a color toner is depleted. Print a status page and see which color toner is at zero, print a maintenance report and check where the color page count is against the PM.
      • JR2ALTA
        • Feb 2010
        • 2033
        How well do you know the customer? Maybe they turned on user restrictions and you're in a "public" b&w mode
        • TEKK09
          • 142
          Negative on both. Was displaying 'Replace MK (A)' which I installed and reset per instructions, and it showed no problems, plus the message went away. But it did not restore color copying. As far as toner, I'm just guessing it would give an indication to that effect, but like I said, it's not saying anything about anything now. And Status Report shows all colors close to full.
          I'm going after color copying accidentally getting locked out by one of the users. Anyone had that or something similar? Or any other thoughts on it? Thanks a lot.
          • TEKK09
            • 142
            Yes thank you. Sounds like something like that is going on. Could you tell me more because there is a lot of information about this in the User's Guide. I see 'Restricting the Use of the Machine' (page 9-67) where this could have been done. Can you tell me if that's what I want, or can you explain further? Thanks a lot.
            • daveh12
              • Jul 2012
              • 157
              Go to system menu, user login/job accounting, job accounting setting, job accounting (local) and check the list of users for restrictions. Even add a new user for yourself with no restrictions for testing and future servicing.
                • 30300
                turn off job accounting
                • TEKK09
                  • 142
                  Okay all it was was... resetting the PM counter (U251). Fixed it. I woulda thought resetting the MK-A would have taken care of that, but didn't. Thanks a lot to all who responded.
