TaskAlfa 3551ci not recognizing finisher
  • copier tech
    • 8176
    [Electrical] TaskAlfa 3551ci not recognizing finisher
    Hoping someone can help, I committed a school boy error today, I disconnected/reconnected the finisher while the machine was still powered on (I know i'm stupid)
    It initially threw an 8800 error, I cleared that with U906 but now the machine won't see the finisher at all.
    Tried updating fw no luck there.
    I'm worried I have a blown a board, has anyone heard of this before!?
  • craigster
    • Apr 2016
    • 201
    Re: TaskAlfa 3551ci not recognizing finisher
    sounds like the board got blown on the finisher, make sure to check the connector harness that is on machine left side and connector that is on the finisher. I had one that it came out of slot on the finisher.
    Good Luck
      • 30308
      Unplug machine from wall for 30 seconds. Kyocera usually don't take out boards
      check the pins on the finisher we had some backed out
        • 23009
        Sadly it's usually the engine board that dies in this situation. I tell other techs that the real damage happens when you go "Ooops!" and immediately plug the finisher back in. So if it happens, and it will ... don't plug it back in. Power down properly, reconnect cable ... and pray. =^..^=
        • habik
          • 2013
          Maybe worth checking ICPs on DFMPWB and EPWB and the lines from PSPWB.
          Firmwares HERE
