CS 406ci C3200
  • copiertech2013
    • Dec 2013
    • 7
    CS 406ci C3200
    I have a Kyocera CS 406ci that I have had some trouble with and cannot figure out the cause or how to fix. The machine threw a C3200 lamp error. Error comes up during boot up, lamp does blink on and in the service modes i can turn the lamp on and off no problem. Following along with the manual, I have replaced the ISU, which comes with the CCD, then replaced the main pwb and the eng pwb, updated firmware. Everything i have thrown at this machine and the code will still not go away. I assume I'm just missing something but I cant figure it out. Please any help will be most appreciated.
  • Ropariva
    • 639
    Re: CS 406ci C3200
    What is the quality like when it copies or scans? Misaligned or dirty optics will give the same error. Is the carriage under the white reference? White reference stained?
      • 22984
      Re: CS 406ci C3200
      Did you do a U906 reset? Reload firmware with each board? =^..^=
      • copiertech2013
        • Dec 2013
        • 7
        Re: CS 406ci C3200
        There is no quality at all. When the machine codes while powering up and finish loading the HDD.
        Have tried a U906 but it does the reset and power off/on but codes the same when powers back up. Yes have updated firmware with each board.
        Got the charts for this machine and tried to run a U411 but when it runs it, the scanner and lamp come one and run across the bed, but then just stays active and never finishes.
        I'm just at a loss.
        • Tonerkiller
          • Oct 2012
          • 665
          Re: CS 406ci C3200
          I would check to see if one of the mirrors are out place
