Task Alpha 300ci
  • COPYDOCAZ
    • Mar 2015
    • 110
    Task Alpha 300ci
    I have a 300ci that is jamming at the transfer belt I read on this site that there is an update with new Mylars. I need a part number for the kit also the update info.
    Mark
  • itchyfinger@att.net
    • Oct 2017
    • 77
    Re: Task Alpha 300ci
    Copystar just released letter stating that as of January 1, 2018 parts for this unit are discontinued. all inventory will be depleted by 12-31-18 if you order the entire belt assembly the updates will be in it. you will need to make sure the firmware is up to date when you install it. may be time to upgrade the customer. belt # 302JZ93070
    • darry1322
      • Oct 2010
      • 817
      Mark
      Most of my 300Ci's jamming at the transfer belt were because of the rubber edge of the belt coming loose and binding the belt.
        • 22997
        Jam codes? =^..^=
        • COPYDOCAZ
          • Mar 2015
          • 110
          i AM ORDERING THE NEW BELT THANKS FOR THE HELP GUYS
          • tonerleak
            • Mar 2012
            • 67
            J31 caused by torn/defective transfer belt.
            • gideon
              • 283
              I have a 300ci that give me J31, but it jam only when printing from the computer and only when the copier is in sleep mode.
              (I posted a question about it last week).
              Hytec support suggest updating the firmware.
              Anyone of you guys encounter a similar j31 with those circumstances?
