TaskAlfa 3252ci ADF
  • simon.cheboi2014
    • Jul 2025
    [Misc] TaskAlfa 3252ci ADF
    ADF of 3252ci refuse to pick paper, the i clean the sensors then worked for a day then fail what could be a permanent solution.
    Re: TaskAlfa 3252ci ADF
    did you check sensors for proper operation?
    what is the count on the ADF?
    Any error code?
    come on man give us more information!
    • sparkycivic
      • Apr 2017
      • 348
      which model adf???
      I had one DP7100 break a plastic hinge part that looked almost normal but jammed a lot J9000.
        • 23007
        Jam codes? =^..^=
        • GeneOR95
          • Feb 2018
          • 161
          Originally posted by sparkycivic
          which model adf???
          I forget offhand which DF does this but there is a small mylar on the sep pad assembly. Straight from the factory this mylar lifts up and catches the paper as it feeds in. I fashioned a flat bladed spudger from a good bamboo chopstick and use it to carefully press the mylar back in place. I have not had any re-occur after repair.
          • pascalb.
            • Aug 2016
            • 47
            Hello,
            it's for the DP7110
            Do not lament,
            do not mock,
            do not hate,
            but understand.
            • GeneOR95
              • Feb 2018
              • 161
              That's the one. If that's the problem putting it in place and smoothing it down fixes it permanently as far as I have found.
              • itchyfinger@att.net
                • Oct 2017
                • 77
                that retard plate with the black mylar. the mylar will keep poping up I have seen just order a new one and claim warranty on the old one
                  • 23007
                  I still don't hear any jam codes. =^..^=
