Taskalfa 4550ci not validating control panel password
  • Greenhive
    Hi all. I recommissioned a TA4550Ci for a client before being installed on site. He wanted the password enabled which I did. However, because it was not set up on a network it will not log in now even using the standard Admin/Admin login/password. It comes up with a message that it cannot be validated as it is not connected to a server. Is there a way to bypass the password/clear the settings so the panel can be accessed again? I cannot get into service mode either because of it. Thanks!
    • 23008
    Re: Taskalfa 4550ci not validating control panel password
    Now there are two types of authentication:
    Local authentication compares your login information to an internal list on the MFP.
    External authentication compares your login information to a list on the DNS Server.
    Very few customers want external authentication. It usually involves typing a full username and password on the keyboard on the copiers touchscreen. Often that's 13 to 20 characters, and if you use the MFP regularly it becomes a serious annoyance, prematurely wearing out your touchscreen.
    Most endusers that authenticate use local authentication. So rather than referencing a remote server, the reference data is is on the HDD of the MFP. It can be as simple as entering a 4 digit numerical password. And it doesn't matter if your device is on the network or not. =^..^=
    • Greenhive
      Thanks blackcat4866. Yes I did see the simplified code at the time but that is too late to undo now with the current issue as I cannot bypass it. When I configured it, I set it up as a local password hence was miffed that it still wants to see a server.
      • pascalb.
        • Aug 2016
        • 47
        Hello,
        Test to make an error code to enter in SIM 021
        Do not lament,
        do not mock,
        do not hate,
        but understand.
