CS 2550ci
  • Techgal
    • Nov 2011
    • 7
    CS 2550ci
    Have a CS 2550ci that has a fax module. When you make copies thru the ADF it is fine. My problem is when they are faxing through the ADF, the other end is receive a total black sheet. If you fax by laying the original on glass, it is ok. Also, if you are scanning to SMB through the ADF it is streaky. So I think it something with the ADF. Do you have any idea, what could be my problem.
    • 23010
    Re: CS 2550ci
    Check that the scanner isn't locked. =^..^=
    • Techgal
      • Nov 2011
      • 7
      Re: CS 2550ci
      The scanner isn't lock. You can lay on glass and faxes great. You can make copies on the glass and through the ADF is the are good.
        • 23010
        Re: CS 2550ci
        I don't think that you understand. The scanner lock can lock the scanner out of home position (slit glass reading), if the lock is engaged while the scanner is away from home position. PLEASE look at the scanner lock. =^..^=
