Kyocera TASKalfa 406ci - front door open message
  • kuby
    • Oct 2007
    • 1402
    Had a TASKalfa 406ci with a bad toner motor (what a pain the take apart). Replaced the motor and put it ALL back together and now I have a front door open message.
    What wires to check and what to look for (going to have to take it all back apart I guess).
    • 23007
    Re: Kyocera TASKalfa 406ci - front door open message
    I haven't even had the pleasure of downloading that manual yet. Typically though the front door switch cuts the 24vdc to the HVT, to make it more difficult for some nut with a length of coathanger to electrocute himself. Personally, I think that Darwin's Law applies here.
    Hopefully you just left a connector unconnected. If that same 24vdc is shorted to frame ground somewhere you can get exactly the same symptom, and possibly a blown power supply too. =^..^=
    How about this?:
