KM 3035 image issue
  • digicor
    • Jul 2008
    • 1153
    KM 3035 image issue
    This machine has been a work horse , the toner was changed two weeks ago, and now this, does it need a 400k maint kit , or is it a voltage issue and it now a boat anchor..?
    see attached20180306165244225.pdf
    before i go and purchase a kit and chargde the client, i would like to know if this is a common thing for these machines when they are at almost 650 k
  • Johnny
    • Feb 2018
    • 9
    Re: KM 3035 image issue
    There is a problem with your charge corona. It could be shorting out because it's just really dirty or maybe the grid is touching the corona housing. I've had this happen many times, it's never been anything serious.
    • digicor
      • Jul 2008
      • 1153
      thanks
      • patrickjlc
        • Feb 2015
        • 225
        see attached[ATTACH]39073[/ATTACH]
        Change the main corona, the ends of yhe grid get covered with toner and short out.
        You can try a cheap test, remove the grid, remove the plastic on the end by the handle. Clean it all, and put the plastic back, and a little scotch tape on top. Put back the grid, reinsert in machine and try it.
        I deal with those machines every day. Some machibes are close to a million copies.
        Sent from my SM-G930V using Tapatalk
        • digicor
          • Jul 2008
          • 1153
          thank you
          • Geo
            • 662
            Looking at your sample you have dots across the image, not a good sign. Most likely the shorting corona caused them and the only cure is a new drum assy. The corona assembly must be cleaned at every toner change per Kyocera toner replacement instructions if not , the corona unit will short out and most likely ruin the drum.
            Sorry
              • 23003
              Sorry
              Yeah, the dots are a bad sign. Those are places where the primary has arced to the drum, damaging it. Looking at the drum surface you would never know it. If you have paper long enough to show it you'll see a pattern in the dots at 127.6mm intervals, one drum circumference. =^..^=
              • Mr2crazed
                • Jun 2014
                • 35
                Be sure to clean the filters on the right side of the machine after replacing the main charge. One is visible when opening the MP door and the other requires removing the right cover.
                • digicor
                  • Jul 2008
                  • 1153
                  ive ordered a 400k kit, found some very reasonable priced, the corona itself was 159 the whole kit with drum unit,dvunit,fuser,corona, feed tires was only258.00 free shipping.... No brainer ill just change it all.
                  Thanks for all the responses
                  • patrickjlc
                    • Feb 2015
                    • 225
                    That is not bad at all, where I work they get the drum and corona (aftermarket) for 300 ea set.....
