KM 3050i
  • craigo
    • Nov 2016
    • 11
    KM 3050i
    Please forgive me in advance I am a Ricoh technician.
    Installed new drum unit and developer. Ran service mode 130 2 prime DV unit. Copies coming out light to blank.
    Ran mode 130 for 10 minute and still light. DV mag roller and unit doesn't seem to have toner in it.
    Any ideas?
    Craig
    • 23010
    Re: KM 3050i
    Does it have the correct toner cartridge? There are three toner cartridges that look identical, and do not interchange: Toner Type A, TK-717, or TK-713B? You should be using TK-713B. The others have different drive couplers, and won't feed any toner out of the cartridge. =^..^=
    • Has Been
      • Nov 2012
      • 48
      Re: KM 3050i
      Any ideas?
      Craig
      Make sure that the transfer roller does not have broken springs and not contacting the drum.
      • Tonerkiller
        • Oct 2012
        • 669
        Re: KM 3050i
        My guess you are working on a 3500i. Did you remove the seal from the dev unit? Is the dev unit being lifted all the way to the drum? What happens when you put the old parts back in? Did you follow the directions that came with the new drum and dev unit?
        • daveh12
          • Jul 2012
          • 157
          Re: KM 3050i
          ahh the seal, it got me before.
          • dalewb74
            • Feb 2018
            • 1167
            Re: KM 3050i
            when you run the 130 process for developer can you hear it actually running? as stated before it takes awhile for the process to finish.
